how CAN I IMPORT PART FORM OPENSCAD
clyde_warner
Member Posts: 2 ✭
New to CAD and OnShape and trying to use for my 3D printer but some models available are made using OpenSCAD and wonder how/if I can import to start using in OnShape directly.
Thank you in advance.
CW
CW
Otherwise you can export as STL in OpenSCAD right away - this will always be mesh data and thus an approximation for round shapes (so set the tesselation resolution high enough, e.g. with "$fa=1; $fs=0.5;"). This is supported for all OpenSCAD features.
