How can I remove these unnecesary facets from this imported STL desighn
Please excuse my inexperience. I'm not sure what terminology I would use to search for this.  I have a simple task I wish to achieve, the following imported .stl model has x2 unnecessary facets in the design highlighted inside the highlighted area.  Is there a simple means by which I can correct this?
Been playing with on-shape for a while now and amazed at the things I have been able to create but I'm not sure how I would edit something imported like this.
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,128 PRO
    This is considered a mesh. You make a sketch and then split the mesh to the sketch. Then delete face the part you don't want. I have had limited success with this, if you find something better let me know.
  • _anton_anton Member, Onshape Employees Posts: 523 image
    The appropriate tool for this is a polygon modeler - Blender, for example. That said, do the extra triangles matter? If you're rendering or 3D-printing, you won't see them anyway, assuming they're coplanar.
  • S1monS1mon Member Posts: 4,040 PRO
    I'm assuming this is rotationally symmetric. I would cut it into 1/14th of the shape, then use some combination of delete face/heal, or replace face to clean up the sector, then mirror/pattern that back to the full shape.
    If you share a public file, I'm sure people can help you.
