Measuring intersections
in General
How do I measure this intersection?
Best regards,
Axel Kollmenter
Axel Kollmenter
EvanReese Member, Mentor Posts: 2,516 PRO
I'd mouse over the face I want to select and use the ~ key to invoke "select other". Press ~ until it selects the face you want. Do that twice till you select them both and measure as usual.0
But if you use the shortcut (for me it's the key with the apostrophe) it also works over the cut area. Never used it before, but I have to remember this key. Thank you!
Axel Kollmenter
When using the "hide part" method, the way I do it is to hide the part that's in the way first, select the part I am trying to get to then show the hidden part to select the second face.
But yeah, the "select other" key is really helpful... I use it a lot in part studios as well if you need to select a sketch region that "inside" a solid for example.
Axel Kollmenter
Twitter: @BryanLAGdesign
