Configurable Properties
Axel_KollmenterAxel_Kollmenter Member Posts: 422 PRO
edited January 2023 in General
Happy new year everyone!
I´ve got a general question about the configurable properties. If I want to configure the properties in a partstudio, all existing configurations automatically pull in.
If I want  to configure the properties in an assembly, I have to manually add all existing configurations. And if I dont add every single config by hand, I cant change the description (in this case) in any other config.
@NeilCooke can you tell me why? Whats the reason behind this?
Thank you
Best regards,
Axel Kollmenter
  • Hans_Ole_LeirvikHans_Ole_Leirvik Member Posts: 82 PRO
    Hi, every combination of configurable parameters creates a unique part, and as you know each Part has a Description.
    Configuratons are related to all parts in a Part Studio, you are actually configuring the Part Studio.
    Hence if you have four configurations you get 4 x 4 parts.
    If you use more Part Studios, one part in each, maybe it will be easier for you ??
  • eric_pestyeric_pesty Member Posts: 2,158 PRO
    My experience is that you have add rows manually in both part studios and assemblies.
    However if you edit properties from a BOM table for a configured part, it will create a row in the configured part properties for the configuration you are editing so maybe that's why you already had some entries in there?
  • jelte_steur814jelte_steur814 Member Posts: 450 PRO
    for some instances, the newly available feature to 'exclude from properties' may be a solution. But only in part studio's and only if the variations of those configurations are not relevant for the BOM either.
    Exclude from properties introduction
    This issue occurs more often. also in assemblies.
    What if you'd want to add a property to the assembly, regardless of the configuration?
    I'd love it if in 'configured properties' for parts or assemblies a wildcard "*" would be available that would imply all configurations for that variable.
