Bookmark Menu
Vivek_PatelVivek_Patel Member Posts: 2 EDU
I frequently find myself bookmarking Onshape documents that are public but not copyable - that I want to come back to for reference. If I could have a system inside of Onshape where I could “save” /  “bookmark” these documents inside of Onshape.
    Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 237 ✭✭✭
    Can using "Labels" help you?
    Henk de Vlaam (NL)
    S1monS1mon Member Posts: 2,412 PRO
    edited April 2023
    Depending on what you want to go back to, you could create your own "bookmark" assembly with a part or assembly from the public documents, and then you can "open linked document" to go to the original.
    If the names of the parts or assemblies or their shapes are not enough to trigger your memory, you could put them in folders that you name with your own text. You could also add your comments to the inserted parts/assemblies.
    Evan_ReeseEvan_Reese Member Posts: 2,068 PRO
    I think labels are the solution here. They are a per-user thing, so you can add them to any doc you want, even other people's public ones. No one else will see the labels you put on documents (I'm pretty sure). It's just for you to organize your stuff how you like.
    Evan Reese / Principal and Industrial Designer with Ovyl
    Website: ovyl.io
    nick_papageorge073nick_papageorge073 Member, csevp Posts: 680 PRO
    I'm missing something.... every onshape document made by a hobby plan is public, and fully copyable.
    A copy is not necessarily in sync with the latest developments of a public file. If that's important to you, then it sounds like labels are a good solution. I haven't used them yet. The one reason to use an assembly as bookmark file is that as far as I know, labels are not synced throughout a company.
    matthew_stacymatthew_stacy Member Posts: 476 PRO
    Labels might form the embryo of a solution, but last I checked, they only offer a single layer for categorizing documents.  Hierarchical, nested labels would provide vastly more utility.
    In my opinion it would also be useful, for non-enterprise users of Onshape, to be able to share that bookmarking structure, both for consistency, and to eliminate duplication of effort.
    In the short term, perhaps some clever API developer will offer us per-user and shared-user bookmarking utilities (...perhaps with a robust AI-based search engine, built-in).
