How can I round the corners using the Sweep tool?
ProApe
Member Posts: 52 ✭
Hello,
How can I prevent Sweep from stopping at each corner and starting again behind the corner, but instead flowing around the corners, making roundings instead of corners?
Kind regards
Kind regards
ProApe
Some posts go through moderation, so they appear once I have approved them.
The sweeping worked after I rounded the corners in the sketch, but at angles<90° the lines get a good bit shorter.
https://cad.onshape.com/documents/7e984dcfffc4b099f0a61b1c/w/9f3ca4f11de67f677d2ccd20/e/bf9455bce6a0a392727bfbe7?renderMode=0&uiState=6446d7f139710662e8c38f87
Not sure what you mean, your links (both taking me to the exact same place) just show a bunch of failed lofts with "missing" faces/paths so I can't tell what you you were trying to do... Can you put a screen grab of the issue here?
You actually don't need a plane as you can place a sketch directly using a mate connector.
I would highly recommend going through some of the self paced learning course in the learning center as it seems you are missing a lot of the basics on how to use this tool...
https://learn.onshape.com/catalog?labels=["Self-Paced Courses"]&values=["Onshape Fundamentals"]
