Add Delta PT Screws to Standard Library
S1mon
Member Posts: 2,412 PRO
I can't find any thread-forming screws to go into plastic bosses in the standard content. Consumer electronics products use these all the time, and even hobbyists with 3D printers might want these screws.
https://www.mcmaster.com/screws/system-of-measurement~metric/steel-thread-forming-screws-for-thin-plastic/
https://www.ejot.com/Industrial-Fasteners-Division/Products/DELTA-PT®/p/VBT_DELTA_PT
https://forum.onshape.com/discussion/15960/self-tapping-screw-smaller-the-2-2-mm-on-the-standard-content
Anything that'll hold plastic together is fine with me. The torx plus™ allows you to remove & re-insert many times before stripping the threads out. I'll get some delta pt, I'm sure they'll be fine.
I voted delta pt up.
What you're showing doesn't describe the thread through, Torx Plus is an "improved" version of the classic Torx drive, but it doesn't have any impact on the thread itself. Delta PT is EJOT's proprietary thread, and they do provide Torx as well as Torx Plus drives as well.
I was looking into creating a library so trademarked stuff could be added to the standard content by outside individuals, but didn't find any references to "How to do this". Could a supplier easily add a library to OS's standard content? It's surprising to me that after 10 years no manufacturers have built parts inside OS for me to use. I'm still downloading McMaster & searching grab cad for models. 3D content central has the 8020 parts catalog and it would be much easier if their catalog was in a OS standard library.
I was thinking that if manufacturers created their own libraries, possibly they could monitor future sales forecasts which would make manufacturing easier for them. If they could monitor how many products were in a design cue, could they forecast production quantities? Also, they could easily handle model changes and a components life cycle. They could bump price changes so BOM's were accurate. They could supply assemblies that work so I don't have to build an air cylinder that actually goes in/out. It seems like a good idea to have them control their parts/assemblies that they're selling to me.
I've always wondered what impact cloud cad would have on the supply chain and its suppliers.
But I agree with you, and it's probaby doable right now buy using configurations. You'd need to model the screw in Onshape to have the most flexibility with configs, but doing that and then making the document public would allow anyone to access it and configure it, it's also possible to make custom properties to tag it as a COTS item. Alternatively the manufacturer could also make it the document private and then require you to will a form on their website to get access (becauce their sales team will want that to then harass you by email)
