How to select all vertical faces of a text?
in Drawings
Hi,
when defining the faces to be offset on a boolean feature ... do you have any idea on how to select all those faces comprising the vertical faces of the text - without having to click each and every one?
thx
thx
https://cad.onshape.com/documents/ae3fe6fbfebe3dd791ece9be/v/43d62369fd2b1a31fd101f8b/e/a4004de599dee6e606fad062
That was the first feature I wrote in Onshape
Both amazing examples to learn ...
Didnt know you can create a surface out of a sketch by an offset. Also didnt know you can boolean two surfaces.
@MichaelPascoe - wow, thank you! @Evan_Reese: very comfortable solution.
seems to be quite vivid and helpful community here
