Drawing feature improvements
dustin_hecocks
Member Posts: 10 ✭
Break: I often model long items and tubing that need a break line to shorten up the view
Change dimension units: It sounds ridiculous, but in my industry, it is common to measure length in CM and diameters in IN. So I need the ability to change units on each dimension. I couldn’t even find where to change the global unit of dimension.
Hide/Show lines: Curves and fillets and whatever put lines into the model that can clutter up a drawing. I need the ability to remove individual line visibility on a regular basis.
BOM: Gotta have a bill of material that automatically generates from the part level properties
Tables: Need to be able to generate tables for a whole host of different reasons.
Branch views: Need the ability to drop in different branches/configurations of the same part/assembly in the drawing. Currently seems locked into the Main or active branch.
Detail View: No brainer, use this everyday.
Glad to see drawings coming along!
BOM needs to be thought carefully concerning real world parts which company buys outside ready assembled but is forced to model in parts for get functionality into model. These need to be shown as 1 part in bom. And when we get configurations in, it will spice up BOM too.
As for the Global Units, They are determined by selecting either an ISO(MM) or ANSI(Inch) template.
in addition
- when zooming in the drawing lines need to thin to show the details.
- ability to 'sketch' and 'define and drive' lines just like in the past studio sketcher.
- I forgot - the ability to 'offset' lines in a drawing and then change their look to dotted, dashed etc. Vital for showing which areas of an extrusion are visible and need the toolmakers care and attention
Jon
Because of the nature in OS where everything is so closely tied together, and history and branches are woven into the mix, I think it would be hugely beneficial to be able to tie your drawing view to a specific version / history point / branch, and also have the option to have it link live to the current / active main branch. Drawings, at least in my mind, is where version control, history, branches, and all the live linking can get complicated. But that may just be the nature of the beast.
