How do I prevent two separate extrusions from having merged faces?
ria_man
Member Posts: 2 EDU
When I extrude a sketch, I extrude it to the same length as another sketch. I want to edit the appearance and make the separate extrusions different colors, but the faces of the extrusions merge and all of it becomes one color instead of the part I just extruded. Is there a way I can fix this or stop the face merge from happening?
Perhaps you can share an image or link to a file?
