Features hidden by extrusion
msandeepmsandeep Member Posts: 16
I am trying to extrude features originally drawn on Top plane, but now hidden by an extrusion. I am unable to select these features. Is there a way to "hide" the first extrusion so that I can select the hidden features?
https://cad.onshape.com/documents/c33a79fdba921323df324d25/w/d34920b58156294bd53f27b1/e/a2171abb1d27916119221368
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 646 PRO
    Keyboard shortcut for Select Other is the ` key (usually to the left of the number 1 on your keyboard).  I use that a lot.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,864
    • If you're trying to cut the grey part from the blue part, use boolean subtract.
    • If you just want to select the sketch areas, use select other (right click the area)
    • You can hide one or both parts using the eye icon in the parts list (or hover over and press Y)
  • msandeepmsandeep Member Posts: 16
    OK, I think I figured out how to do this - by selecting the extruded hub (in blue) and right-click and "make transparent". Then I can select the triangular region and use it for extrude.
