Enabling non-associative linked bodies?
Dean_GardnerDean_Gardner Member Posts: 114 PRO
Is there a way to de-link a derived body reference in part studio?  I.e. freeze the derived body status in time and delink its association with the founding part.  Can this be done retrospectively?
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,454 PRO
    Switching to a version will break the update cycle (i.e. freeze), no need to further "disconnect" as that wouldn't get you any further performance gains.
    You can change the reference of the derive to a specific version, it doesn't remove the link but it becomes "static".
    Maybe the "bigger" question would why you would need to do this, i.e. what is your end goal?
  • Dean_GardnerDean_Gardner Member Posts: 114 PRO
    Speed.  I have a very complex surface model that i need to reference in another model.  It's typical to break the link and freeze some I/F surfaces in order for the model to avoid hanging for long periods of time.  If I could show you, you would understand... But hopefully leaving the version in time should help reduce this.
    I found that creating composite 0mm offsets of the interfaces that i need, can be copied across too - rather than whole parts.  This works nicely.
    edited May 2023
    @Dean_Gardner Sometimes I want this also.
    I want a guide to help me design something new that has no history or references. I just want it to be static and unencumbered with history. To do this, I take the surfaces from a previous model and export them via step or parasolids, bring'm back into a part studio then create a derived reference to this neutered surface geometry. It creates a lightweight guide for designing the next generation without worrying about updates. I never make any references to the neutered surface geometry and I can always delete it but I never do.
    @billy2 , that is what i do too, when i have a heavy surface model, although many people would think this is crazy.  I sometimes have surface model with 1000+ features, especially motorsport panels, casings, etc.
  • S1monS1mon Member Posts: 3,719 PRO
    If you derive a version as @eric_pesty mentioned, it will speed things up AND you can update it if needed.
