  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,990 image
    Don't try to loft as a solid with an internal void - it won't work. Create a sketch on both side of just the external profile and loft (using "connections" to control any twist) then use the Shell command to hollow that section out.
  • luk_kukluk_kuk Member Posts: 10
    Yes, this is it. Thank you.
