Preserve ID through a try/catch?
EvanReese
Member, Mentor Posts: 2,525 PRO
I have a feature that I know will fail in certain scenarios, and I'd like to use a try/catch statement to first try my ideal one, and, if it fails, change some settings and try again. Here's what I've tested:
var mainBody;
try silent
extrude(context, id + "mainBody", mainDef);
mainBody = qCreatedBy(id + "mainBody", EntityType.BODY);
catch (error)
mainDef.hasDraft = false;
mainDef.hasSecondDirectionDraft = false;
}This isn't working for me. If I change the id of the function in the catch statement as follows, it worksextrude(context, id + "mainBodyWithoutDraft", mainDef); mainBody = qCreatedBy(id + "mainBodyWithoutDraft", EntityType.BODY);The issue is that anything downstream related to this fails, because the id of the resulting body is different. How can I make featurescript treat the bodies from either function as the same thing? is opNameEntity() helpful here?
NeilCooke
Moderator, Onshape Employees Posts: 5,891
Here's a simple example I coded just to check my syntax:const extrudeId = id + "extrude"; for (var i in [0, 1]) // max 2 loops - change these numbers to make extrude fail/succeed in this test { startFeature(context, extrudeId); try silent { opExtrude(context, extrudeId + "body", { "entities" : definition.myQuery, "direction" : evOwnerSketchPlane(context, { "entity" : definition.myQuery }).normal, "endBound" : BoundingType.BLIND, "endDepth" : i * inch }); endFeature(context, extrudeId); // execution gets this far so feature completed break; } catch { abortFeature(context, extrudeId); // execution fails so do not commit/keep id } } opFillet(context, id + "fillet", { "entities" : qCreatedBy(extrudeId, EntityType.EDGE), "radius" : 0.1 * inch });
Senior Director, Technical Services, EMEA0 -
lana
Onshape Employees Posts: 736
@Evan_Reese
try using id + unstableComponent("extrudeWDraft" ) and id + unstableComponent("extrudeNoDraft") . unstableComponent will prepend * to the input string, that would make results of two features interchangeable for downstream references.
1
I case I'm actually asking the wrong thing altogether, I'm solving for cases where extruding with draft will fail because there won't be any faces to draft. In those cases I'd like to just switch to extruding without draft without the user having to know that's happening, and without wrecking any downstream relationships. One workaround I'd like to avoid is copying the entire extrude feature code base and making the draft part a "try" statement instead of failing the feature. I might be okay with just always extruding without draft and manually adding the draft code to my feature, but intuition says there's a much better way to solve that, and I'd like to know what it is.
I looked at your example of the startFeature() and abortFeature() functions, but I still don't understand how to use them. Here's what I tried, which I'm sure will look silly once I know what they actually do, but there's not documentation on them because they're marked @internal.
const extrudeId = id + "mainBody"; startFeature(context, extrudeId); try silent { extrude(context, extrudeId, mainDef); } catch (error) { abortFeature(context, extrudeId); mainDef.hasDraft = false; mainDef.hasSecondDirectionDraft = false; extrude(context, extrudeId + "test", mainDef); } const mainBody = qCreatedBy(id + "mainBody", EntityType.BODY);The Onsherpa | Reach peak Onshape productivity
const extrudeId = id + "mainBody"; startFeature(context, extrudeId); var needsAbort =true; try silent { extrude(context, extrudeId, mainDef); needsAbort =false; endFeature(context, extrudeId));//This can throw an error. if it does, catch below will try to abort the already ended feature which results in a error } catch (error) { if(needsAbort==true) abortFeature(context, extrudeId); mainDef.hasDraft = false; mainDef.hasSecondDirectionDraft = false; extrude(context, extrudeId + "test", mainDef); } const mainBody = qCreatedBy(extrudeId, EntityType.BODY);Thanks! It still doesn't solve the issue I'm trying to solve, which is that the "try extrude" body is different than the "catch extrude" body, which will make downstream things fail. A hack I can think of which I think would solve my issue might be:
- Do a dummy "test extrude" to check whether it will fail
- Use that work/fail to set a boolean
- Based on the bool, turn draft off for the "real extrude"
- delete the "test extrude body"
That just feels like a big kludge, which is usually a clue to me that I'm doing it "wrong" and I have something I can learn. I also don't want to add that extra overhead if I don't need to. Any other ideas?The Onsherpa | Reach peak Onshape productivity
var draftCausesFailure = false; try silent { extrude(context, id + "testExtrude", mainDef); } catch (error) { draftCausesFailure = true; } if (draftCausesFailure) { mainDef.hasDraft = false; mainDef.hasSecondDirectionDraft = false; } else { opDeleteBodies(context, id + "deleteTestExtrude", { "entities" : qCreatedBy(id + "testExtrude", EntityType.BODY) }); } extrude(context, id + "mainBody", mainDef); const mainBody = qCreatedBy(id + "mainBody", EntityType.BODY);The Onsherpa | Reach peak Onshape productivity
const extrudeId = id + "extrude"; for (var i in [0, 1]) // max 2 loops - change these numbers to make extrude fail/succeed in this test { startFeature(context, extrudeId); try silent { opExtrude(context, extrudeId + "body", { "entities" : definition.myQuery, "direction" : evOwnerSketchPlane(context, { "entity" : definition.myQuery }).normal, "endBound" : BoundingType.BLIND, "endDepth" : i * inch }); endFeature(context, extrudeId); // execution gets this far so feature completed break; } catch { abortFeature(context, extrudeId); // execution fails so do not commit/keep id } } opFillet(context, id + "fillet", { "entities" : qCreatedBy(extrudeId, EntityType.EDGE), "radius" : 0.1 * inch });for a very simple feature, here i create 2 sketches, if sketch 1 query is defined (selected) then it creates an extrude. if sketch 1 is undefined (unselected. if you break the sketch instead this will break the query for the sketch) then it goes to sketch2. with this you can boolean another part and unselect/reselect the sketch 1 and have the boolean work.
annotation { "Feature Type Name" : "id test", "Editing Logic Function" : "assignIdentityEditingLogic" } export const idtest = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Sketch", "Filter" : SketchObject.YES, "MaxNumberOfPicks" : 1 } definition.sketch is Query; annotation { "Name" : "Sketch2", "Filter" : SketchObject.YES, "MaxNumberOfPicks" : 1 } definition.sketch2 is Query; annotation { "Name" : "Identity", "UIHint" : UIHint.READ_ONLY} // "UIHint" : "UNCONFIGURABLE" } definition.identity is string; } { var ent; try silent { opExtrude(context, id + "extrude1", { "entities" : definition.sketch, "direction" : evOwnerSketchPlane(context, {"entity" : definition.sketch}).normal, "endBound" : BoundingType.BLIND, "endDepth" : 1 * inch }); ent = qCreatedBy(id + "extrude1", EntityType.BODY); } catch { opExtrude(context, id + "extrude2", { "entities" : definition.sketch2, "direction" : evOwnerSketchPlane(context, {"entity" : definition.sketch2}).normal, "endBound" : BoundingType.BLIND, "endDepth" : 1 * inch }); ent = qCreatedBy(id + "extrude2", EntityType.BODY); } opNameEntity(context, id, { "entity" : ent, "entityName" : definition.identity}); }); export function assignIdentityEditingLogic(context is Context, id is Id, oldDefinition is map, definition is map, specifiedParameters is map) returns map { if (specifiedParameters.identity != true) definition.identity = toIdentity(id); return definition; } function toIdentity(id is Id) returns string { var out is string = id[0]; for (var i = 1; i < size(id); i += 1) { out ~= "." ~ id[i]; } return out; }The Onsherpa | Reach peak Onshape productivity
thanks! This looks like a variation of the Assign Identity feature code. This is definitely a handy thing to know for another scenario. I tried something like this, but as you say, I'd need to assign the ID for every entity (body, edge, vertex), which in my case, could be thousands. I ended up going with the startFeature() method, which is exactly what I was looking for.
Actually that wasn't the ticket after all, but it feels like the right solution if it can be made to work. Here's an example document of exactly the case I'm trying to solve for. The reason draft makes it fail is that there are no side faces to draft. With the native extrude, this doesn't matter, because you just un-check draft, but for my thing I want to do downstream things to that part either way, which might also have draft.
Here's the code I'm working with based on what you sent.
var mainDef = definition; const extrudeId = id + "mainExtrude"; for (var i = 0; i < 2; i += 1) { startFeature(context, extrudeId); try { extrude(context, extrudeId, mainDef); endFeature(context, extrudeId); // execution gets this far so feature completed break; } catch { abortFeature(context, extrudeId); // execution fails so do not commit/keep id mainDef.hasDraft = false; mainDef.hasSecondDirectionDraft = false; } } const mainBody = qCreatedBy(extrudeId, EntityType.BODY); debug(context, mainBody, DebugColor.RED);The Onsherpa | Reach peak Onshape productivity
That solved it! Quite simply I should add. Thanks so much for taking the time.
I can't say I understand what's going on here though. I'm looking at the context.fs feature studio and see that unstableComponent() just prepends ANY_ID to a string and that ANY_ID is declared as "*", and that treats it as a wildcard, which a google search tells me it's kind of like "." in regex, but that's about where I fizzle out. Is there somewhere good for me to read up on it?
