LOFT question
luk_kuk
Member Posts: 10 ✭
How to make loft between these two objects?
NeilCooke
Moderator, Onshape Employees Posts: 5,990
Don't try to loft as a solid with an internal void - it won't work. Create a sketch on both side of just the external profile and loft (using "connections" to control any twist) then use the Shell command to hollow that section out.Senior Director, Technical Services, EMEA0
