Is there a good way to reorient "Part 1" for STL export?
Hello,
I have a Part Studio with multiple parts (Part 1, Part 2,...) and I am exporting only Part 1 to a STL. Part 1 needs to be reoriented for 3D Printing. I thought of putting only "Part 1" into an assembly so it could be oriented properly... but you can't "Export to STL..." an assembly. I don't want to Transform the existing Part 1 in the current Part Studio. I could Copy Part 1 and reorient it, and export Part X to the STL. (Maybe I just answered my own question.) I thought of opening a new Part Studio and "copying" Part 1 into it so I could manipulate it there. Is there a way to do that I haven't yet?? IGES out and back in??
3dcad Member, OS Professional, Mentor Posts: 2,476 PRO
I would probably just duplicate the part studio (RMB menu on tab) and remove other parts, then re-orient part for export. It will be a copy and if you wan't to make changes to the original, you need to copy and re-orient again.//rami5
