Drawings and the journey of understanding what drive the inputs (a question)
Jose_Montalvo
                    Member Posts: 12 EDU
                    The point of concern:
Sheet numbers
Sheet x of y.
So in my document, I have a multi-sheet drawings that are linked to the parent assembly. I also have individual drawings of individual parts scattered in folders, my attempt of organized chaos. I wanna know how I should go about making and exporting drawings of multiple parts but having the "sheet x of y" information already updated. I say export as opposed to print to get the higher resolution from JPEG to then get slapped onto other reports.
Why does export only work on the current sheet of a multi-sheet drawing? One thing that would fix my issue would be to be able to export multiple sheets from within the same drawing tab but I don't think I can do that. If I go the "export multiple drawings" route, I would need to have multiple drawings in different tabs but I don't know how to get the "sheet x of y" data to input itself and know that it is part of a larger "stack".
I really feel like I am not using drawings as well as I can be. I wanna know how to really leverage the small details that seem to take a lot of time when I don't think about them from the beginning of the document building.
here is the doc link if you wanna see.
https://cad.onshape.com/documents/267b8aece9a2251ecaa9d496/w/e33f5a5020c0ccaccef3bc86/e/226b8b6fd1c82181fe2923df
                        Sheet numbers
Sheet x of y.
With the number of drawings I saw it's pretty clear to me somewhere there is going to be someone asking for some more explanation or adjusting some dimension, tolerance, etc. and then keeping track of your latest versions is going to become quite a headache. I'd also start making using of versioning anything you are just ordering should just be a version, anything that you are just reworking should probably just be a derived part.
I also need some more time to sit down and understand how to do the versioning part of building an assembly.
