Is there a way to realign an assembly to a view?
leon_goldman
Member Posts: 8 ✭
I have created an assembly, but it has ended up not aligned with one of the standard views. Is there a way to hightlight the assembly as a whole and then have it realign with the "front" view, or "top view"?
viru
Member, Developers Posts: 619 ✭✭✭✭
@leon_goldman , You can position your assembly without grouping parts and suppressing constrain . You need to give fastened constrain with respect to origin according to your required position as shown in below attached video.
You can also create and use mate connector of any part for constraining with origin. By editing mate connector you can give any position as per your requirement.
7
Thank you.
Leon
Share model and we can take a look.
Best assembly practice is to first insert and position the main part (say the housing, for a gearbox), then RMB on it in the tree and choose "Fix". Now you can mate all the other parts relative to this main part, either directly, or to parts already mated to it.
Then if you need to reorient the assembly, all you have to do is Unfix that first part in the tree (which will have an icon, indicating it is fixed), apply the Triad method described by @philip_thomas so it produces the desired views, (except you will not need to select all the parts, just the first one)
ON EDIT : and then refix it.
But da_vicki's method in the next post is more rigorous and robust, as well as easier to modulate, as he points out.
