very low frame at onshape
lfrmmslfrmms Member Posts: 5 EDU
i am a solidworks user. my computer has intel hd 3000 graphic card and nvdia card. i only use intel hd 3000 graphic card because nvdia card is faulty.
I uploaded a project that I used in solidworks on my computer to onshape. I feel very, very low fps value in onshape. it is not a complex assembly.
I can move the design fluently in solidworks.
I have tried in different browsers and the problem persists. I don't know if this is the problem or not.
as if the fps value in the browser is between 5-10. the same assembly fps value in solidworks is like 60 fps. it works very fluently.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    As you can see from the check your graphics is very poor. If you press CTRL+D you’ll see the exact FPS you are getting.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,035 PRO
    Have you tried updating the nvidia firmware from nvidia's site? That might fix your GPU issue and then you'll be able to use it. I had that issue on a PC a few years ago when I was using another CAD program.
  • S1monS1mon Member Posts: 3,782 PRO
    Also try running https://cad.onshape.com/check
    It’s quite possible with some browsers that they’ll default to integrated graphics. Follow the instructions about graphic performance issues:
  • lfrmmslfrmms Member Posts: 5 EDU
    I had windows 10 on my computer. Intel HD 3000 graphics card supports windows 7. so i installed windows 7 on my computer.
    I didn't know about the ctrl+d command. Thank you very much for this command. After learning this command, when I tested it on windows 10, it gave 5-6 fps. After installing windows 7, it gives 35-30 fps.
