Need some help with design, thank you.
k_vw
Member Posts: 9 ✭
Hello everyone, I'm new to 3d drawing and Oneshape and I've already watched several YT videos from which I've learned quite a bit.
But now I don't know what the best approach is for the next design and which tool to use.
I'd love to design the ribs in the tray, like in the picture, but I really don't know how to get started.
I have already designed the tray.
Can someone help me with this please?
Thanks.
john_mcclary
Member, Developers Posts: 3,998 PRO
Select the inside face of your channel, and sketch a slot shape then extrude it, then pattern
I would start with a line, then use the slot tool (it's under the drop down menu for offset in the sketch tools)
Dimension the slots how you need them
Extrude new
Mirror New
Part Pattern, Add, merge all
nick_papageorge_dayjob
Member, csevp Posts: 1,034 PRO
@k_vw
Nice job. From a manufacturing perspective, it might be a good idea to have the bottoms of the ribs merge with the bottom of the C-channel, and get rid of the radius on their bottom. This way, your 3D printer won't need any support to print this part.3
Extrude new
Mirror New
