Having trouble chamfering stencil letters
benj_fitzpatrick
Member Posts: 13 ✭
My project is to make some 3d printed stencils so I can use a dobber/marker (perhaps spray paint in a pinch) to add the text on top of painted metal. I would like to add a chamfer to the stencil text to make it easier for the large marker tips to make it into all of the corners. Most of the characters work reasonably well, but there is part of zero that breaks the chamfer and the same thing happens for the lower case "l". Thoughts on how I can get this to work properly?
_anton
Member, Onshape Employees Posts: 506
Empirical observation: extrude+draft can work better than a chamfer. Example: https://cad.onshape.com/documents/9af54e85e3a485c9a3b6ee4b/w/0b88cc1f92683f04b8ac98a2/e/fd64bfdd52f518b89073c30a
If you change the configuration variable from 2mm to 3mm, the chamfer fails but the extrude+draft succeeds, though not without artifacts.
I think, with some thought, the approach could be mapped onto your use case.1 -
EvanReese
Member, Mentor Posts: 2,697 PRO
Extrude+draft is what I came here to suggest._anton said:Empirical observation: extrude+draft can work better than a chamfer. Example: https://cad.onshape.com/documents/9af54e85e3a485c9a3b6ee4b/w/0b88cc1f92683f04b8ac98a2/e/fd64bfdd52f518b89073c30a
