How to make a grid of thousands of millimeter holes
Hello all,
I have been trying to make a greed of roughly 120mm by 60mm and punching it full of holes.
So I extructed a rectangle, and used repeating pattern to punch holes of 1mm size shaped like hexagons.
But repeating pattern just stops working after so many repetitions (as image shows it stopped after repeating the first two rows of the grid 8 times).
Is there a way to repeat this simple shape a thousand times or more to make a fine grid ?
Thanks in advance for your help
  • _anton_anton Member, Onshape Employees Posts: 528 image
    edited June 2023
    I'd just make one hole (though maybe two if they're hexagonal), then use the linear pattern feature (i.e., not in the sketch) to pattern the resulting faces.
    (I should also drop the requisite cautionary note that modeling thousands of holes in parametric CAD should be avoided if at all possible.)
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 182 image
    Hey @alexis_garnier767,
    I would also recommend to use "face pattern" instead of a feature pattern, that should result in better performance if you have a lot of instances.
    You can check out this Tech Tip for more info: https://www.onshape.com/en/resource-center/tech-tips/tech-tip-how-to-create-faster-patterns-in-onshape
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,987 image
    Also take a look at the custom feature “fill pattern” (click on + menu, top right to find it). Probably the fastest method.
  • EvanReeseEvanReese Member, Mentor Posts: 2,867 PRO
    I think @NeilCooke is right that Fill Pattern is the way to do this if you've gotta, and everyone here is right that you should NOT do this unless you've gotta. It's going to be slow no matter what.
