Why can't I define a variable as a measured angle?
StephenG
Member Posts: 383 ✭✭✭
It is possible with an "Assigned" variable
but not with with "Measured".
8
as in...
Would restricting measured angles to a 3 point method, where the 2nd point is designated the angle vertex and returning a value <=180 degrees address the issue?
Set #angle with Measure Value, then make a new variable also called #angle and make it equal to the following:
This will look at the measured angle and the supplementary angle and return the smaller of the two.
Question: Why "(180 * degree)" instead of "(180 degree)"? I have never seen units applied using an "*".
When you have to vectors selected, you don't know anything else. To make this work you'd have to pick 2 vertices to determine which angle you want.
Once you figure this out, post it, it'll be interesting.
Oh yeah, that's a FeatureScript habit. That's the actual way to represent it, but the normal dialogue boxes automatically fixes it for you so if you type "1mm" it fixes it to "1 * millimeter" internally. you could totally just do (180deg).
