FeatureScript Table Output Help
Hello all,
I am trying to make my first feature script with Onshape, but my lack of experience with coding and the platform is making it difficult.
I wanted to make a feature which takes all my wire lengths within an assembly and outputs them into a 2 column table with 'Wire Name' and 'Length' as the column names. Before I was doing all this manually but it gets tedious, especially when wire lengths needs to constantly change.
I tried using the define table function, but failed to produce tables. I am wondering if I need to define a variable or read attributes of the wiring in addition. I added screenshots for the wiring data I'm looking at and the code I started on. Thank you all for the help!!
The only portion I need currently from the Cable Routing 2.0 is to output the lengths to a custom table. I'll look into the cable routing feature script code
https://cad.onshape.com/documents/d7646aa1f428392f60bfd0f0/w/dfb67fc2be359897542a6c61/e/e28ddde9f860e79eee77368d
