Is Extrude only linear?
Not sure my question makes sense. What I'm trying to do is extrude, but not in a linear, block-like way, but angularly, like a valley or a mountain, which will result in 2 planes of extrusion instead of 3. Can Onshape do that?
Thank you.
Thank you.
Jacob_Corder Member Posts: 137 PRO
@martin_barnard
Are you trying to make a thickened letter V or a sheet body? if a sheet body, then draw a non closed sketch, select extrude, select Surface, then select the sketch edges you want to extrude.0 -
glen_dewsbury Member Posts: 1,056 PRO
@martin_barnard
Here's some samples based on Neil Steve & Jacob's questions.
many ways to skin a cat.
https://cad.onshape.com/documents/987f6c5ff80b113d17c589aa/w/6bc70008f4762275c546f3b3/e/62214143f36b64aad1b6093f
