Sketch: Intersect of a face not working (plane does)
"Project the intersection of a surface, or face ... to the active sketch plane"
This does not work from a face of a part.
Steps:
- In sketch mode, select Intersect tool
- select the face as shown in the picture
Expectation:
- I will get a line on the active sketch, presenting the intersection of said face (extension of it) with the sketch plane.
Actual:
- An error banner shows up:
Work-around:
- Create a plane (before the Sketch step); offset 0mm from the said part face
- Use intersection with said plane; that works
The document to showcase this: https://cad.onshape.com/documents/453d32f9a17ead3e10d896cc/w/a0d1a3cbe0b284d7419b19da/e/b8139646234764853c29e822?renderMode=0&uiState=64abb4efd68a1263fd1ee8c4
// I need this in making veneer constructs, with angles between the plates, to project the neighbouring plane to one, in order to create "teeth" between the parts.
You can use projected curve in 3D mode to place a curve on any given face that can be used later to make a sketch.
https://cad.onshape.com/documents/d2668de69711420f803a74b4/w/10bdd4c3ecd73814b8a3dc0d/e/0baf52182dd690c3c53e9a40
As to sharing, I thought I've made the document as public as I can. Will try to find out what's the recommended way to share an MVP.
I did note that the line I drew did not want to have any existing constraints like hor/vert since the coincident causes over constrained condition.
ah yeah good thought. That could happen. Onshape seems to do pretty well at not failing with redundant constraints, but not always. One of the modifier keys (maybe shift?) disables automatic constraint snapping to make that easier to not add.
@asko_kauppi
I use that one a lot since faces are usually a more stable reference than an edge, especially if it's a pretty big fundamental face.
