Folder in Mate Features
lazăr_mihailazăr_mihai Member Posts: 5 EDU
For organisation reasons it would be very nice to be able to add folders inside the Mate Features list inside of an Assembly
Is there any way to do this currently ?
of not, are there any plans to add this functionality ?
  • MichaelPascoeMichaelPascoe Member Posts: 2,817 PRO
    edited July 2023 Answer ✓
    This was Implemented on September 20, 2021 06:19 in rel-1.136
    https://forum.onshape.com/discussion/12562/folders-in-assembly
    Select the mates that you want to add to a folder, then click the  +📁   icon near the top of the side panel. You can also right click the selection of mates and select "Add selection to folder".
    If this button is not showing up, make sure your document has been updated to the latest version. If you declined the update but decided you still want the update for that document after all, follow Neil's approrach:
    NeilCooke said:
    You are correct - the document has not been upgraded, probably due to the fact that it has not been opened for a long time. You should contact support to have them upgrade it for you, or you can try this hack yourself:
    • Create a branch from "Start"
    • The branch will ask to update - let it do so, then reload the doc
    • Go to main, then merge the branch into main with "keep main" as the default action
    • Main will ask to update - let it do so, then reload the doc
    • Delete the branch
    RENDERCAD
    • Delete the branch
    RENDERCAD
