issues with frames
stefan_nilssonstefan_nilsson Member Posts: 13 ✭✭
edited July 2023 in General
First i selected the sketch surface describing the outline of the sheet and made a frame around it using my own profile. I could not find a way to align the inner edge of the profile with the outer edge of the sheet. I solved this by offsetting the outline inwards by the appropriate distance.
The next issue occurred when creating a second sheet aligned to the top edge. This time the profile was aligned with world coordinates. This was fixed by measuring the angle and cutting and pasting.
Both these methods seem unnecessary awkward so i like to know if there is a simpler way to solve this
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,549 PRO
    See this discussion on frame alignment (relevant to your second question): https://forum.onshape.com/discussion/20950/frame-generator-alignment
    For the first one doesn't selecting the correct point on the first frame fix this? And if not it is possible to specify a custom point using the frame tagging tools (look it up in the frame help).
  • stefan_nilssonstefan_nilsson Member Posts: 13 ✭✭
    edited July 2023
    That did solve it thank you. I had to create a custom alignment point
    For the angle i had to select the edges individually. When selecting the whole surface i found no way to control what the first edge is. Also i wonder what happens when the plane i skewed in more than one direction?
