Getting to "fully defined"
Reference document: Octagonal pedestal - multipart
https://cad.onshape.com/documents/28044d76fae64781bc7c9c46/w/f0b392a79f784531824bf25d/e/f31eb6eef1ea46ceb4d1ee03
Part Studio: Parts Rev 2
Sketch 1
I've created an octagon shape with two lines using offset. To this point, the sketch is fully defined.
I added a box at the 9 o'clock position using the corner box tool. The box is related to the inner line of the octagon. The sketch is still fully defined.
I copy the box 8 times (7 replicas) using the circular patter tool. The original box remains fully defined, the 7 replicas are NOT fully defined.
I try adding additional relationships to the box at the 10:30 position and succeed in fully defining the box sides but not the whole box. Trying other relationships over defines the entire sketch.
Help. What is necessary to define the replicas without over defiining the whole sketch. OnShape seems to report what relationships exist, but is not very helping in saying what additional definitions or relationships it wants.
Sketch 1
3dcad Member, OS Professional, Mentor Posts: 2,476 PRO
@thomas_holford
The problem was that the middle point of circular pattern was not constrained to origin.
The easy way to test constraints is simple trying to drag things around and see what is moving. See the image below.
Here is fixed version. All I did was coincident constraint between origin and middle point of circular pattern and deleted one over constraining dimension.
https://cad.onshape.com/documents/d29ff8e74a0f49809e533f48/w/48fedb2064cc4f30a27ee6e8/e/07fb12e6529d41ed9783a904
//rami6 -
jakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 667
When making a circular pattern, the system originally guesses the center of rotation as the origin but doesn't apply a coincident constraint if it isn't moved. This is to reduce the need to delete a constraint if the guessed position isn't correct. Next time, if you want it to be coincident with the origin, while creating the circular pattern move the center around a bit until there is a coincident snap to the origin. At this point, the center of rotation will be constrained to the origin.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com6
What I am taking away is that for anything to be fully defined, it has to have a constraining relationship to the origin.
Correct?
1. I made an arbitrary located rectangle in sketch 1. The lines and vertices are blue because they are under-defined. This means that their position isn't fully defined and I can grab and move them. I will save this sketch being under-defined.
2. On a new sketch, I dimensioned a rectangle relative to the rectangle on sketch 1. As far as sketch 2 is concerned, sketch 1 has been committed and solved, the position of the first rectangle is fully defined. Because of this, I have defined my new rectangle off of the sketch 1 rectangle and it is fully defined. There is no relationship to the origin here.
3. If I go back to sketch 1 and move my rectangle, the sketch 2 rectangle will move accordingly. It is being solved after sketch 1 is solved relative to the rectangle in sketch 1.
It goes well past answering the immediate question, to clarify something much more fundamental.
Your third step is also a great example of non-trivial, non-obvious pitfalls from leaving sketch geometry under-defined.
Can any help me? https://cad.onshape.com/documents/f4bcd89822f5178115c3f42b/w/c10aceb129ea421d3da22675/e/d36ab8b3e83a234929585d11
