Printable Onshape Keyboard/Mouse Shortcuts Quick Reference Card
StephenGStephenG Member Posts: 380 ✭✭✭
Keyboard shortcuts are an incredibly valuable feature and productivity aid while using Onshape.
Several years ago I made a Quick Reference card based on the on-screen shortcuts help ("?"). I have been religiously been maintaining this document over the years and would like to share it with the greater user community as a thank you for all the great support that exists in the User Forum.
It is organized differently than the built-in on screen shortcut help to improve its usability. It has been augmented to include useful information about specific shortcuts and contains more detail about 3-button mouse functionality.
The reference card is 2-sided and is designed to print on a 8.5x11 card stock.  Following are preview images of the front and back.
        --- Front ---
        --- Back ---
A printable PDF of the document can be found here: https://1drv.ms/b/s!AuMUtTIiNawOgqVOsNY6CvJoA4mUjA?e=SYCbW1
Improvement suggestions welcome.
My intent to maintain this reference card as Onshape is updated.  Note: If you post a comment to this post you will automatically be informed when I create a new version of the reference card.
  • wayne_sauderwayne_sauder Member, csevp Posts: 592 PRO
    @StephenG
    That is great. The onscreen documentation is helpful but I never got it to print in a format that I like. Thanks for doing this.
    @StephenG
    Thank you for the update and doing such a thorough job of getting the shortcuts.  I have been using your previous versions and really adds to the efficiency of Onshape.
    www.accuratepattern.com
  • StephenGStephenG Member Posts: 380 ✭✭✭
    Reference card updated to include recent shortcuts added in 2023-04-12 update...
    New keyboard shortcut for Revolve (SHIFT + w)
    New keyboard shortcut for Hide/show sketches (SHIFT + h)
    New keyboard shortcut for sketch point (SHIFT + s)
    New sketch shortcut from line to tangent arc (hover over endpoint to toggle or SHIFT + a
    Plus keyboard shortcut for 2D sketch curve analysis display (SHIFT + c)
    Printable PDF of the document can be found here: https://1drv.ms/b/s!AuMUtTIiNawOhKoag49Pc7yx2jiDDg?e=UEyfDq
    Note: Found it impossible to fit the new shortcuts into existing reference card framework. Had to convert some of the shortcut descriptions to endnotes which appear on 2nd page (back of reference card).
  • GWS50GWS50 Member Posts: 440 PRO
    This is most useful, thank you
  • charles_reynolds211charles_reynolds211 Member Posts: 2
    Thank you!
  • aandersonaanderson Member Posts: 4
    This is something I was just thinking about doing, thanks!
    Updated reference card to incorporate all the new constraint shortcuts added in the latest (1.172, 2023-11-06) update.
    Changed the method the shortcuts were documented in the Word document from a table to columns.
    Incorporated the new PTC Onshape logo and green color scheme.
    Reordered shortcuts in lists so they follow the order they appear in the command icon row.
        --- Front side ----
        --- Back Side ---
    Printable PDF of the updated reference card can be found here: https://1drv.ms/b/s!AuMUtTIiNawOhLxyRVn19aUbO6Dk-Q?e=qnCbSV
    Commentary:
    Never understood the need/value to allow users to change existing (default) shortcuts. It is my understanding that users want to be able to create shortcuts for functions that do not currently have one. There is a limit to what can be accomplished with single key, or meta key+key stroke shortcuts in a browser environment. Clearly someone at Onshape is going to have to rethink how shortcuts are implemented to make it possible to expand the number of shortcuts.
  • SethFSethF Member Posts: 131 PRO
    @StephenG Thanks!
  • w_s856w_s856 Member Posts: 46
    Thank you very much! It prints very well on an A4 page as well (fit to paper)
    Updated reference card to reflect the 3D Viewing (rotation) behavior change using the cursor keys in the latest update (1.191, 2024-12-13).
    Here is the downloadable PDF…
  • charles_jesseecharles_jessee Member Posts: 6
    Great - thanks!
  • edward_omagbemiedward_omagbemi Member Posts: 10
    Thank you so much for this reference sheet. I don't use onshape all the time and it's really frustrating to have forgotten the keyboard shortcuts and stuffing around. This will help big time. Thanks
