removing embossed text - best way?
jacob_hämmerle039
Member Posts: 16 ✭
I got a model where there is text embossed (-0.5mm)
the text is not parametric anymore but as faces and edges part of the model - so i can probably only remove it by by removing all those faces comprising the embossed text.
they only way i managed to do it is to select all faces that are part of the text (of every letter manually) and use the delete faces feature. I couldnt use the mouse & window select cause it would also select the edges and then the "delete faces" would not work.
what other ways are there that are more efficient? is there a way to select the faces only with window drag - but not the edges ... or whatever?
thx
thx
https://cad.onshape.com/help/Content/createselection.htm?Highlight=create selection
If you already have the Delete face feature open, a window select should only select the faces.
thanks for both of your answers!
Sounds solved, but sometimes it's easier to just sketch a rectangle over it and extrude to fill it in
