Forum Discussion Format/Code does not work
hervé_pipon
Member Posts: 60 ✭✭
Hello,
Find "test: same with code formatting" at the beginning
I'm using Chrome Version 115.0.5790.110
When I want to use Format/Code on the forum, it doesn't work.
See on https://forum.onshape.com/discussion/21555/skfitspline-and-bsplinecurve-controlpoints/Find "test: same with code formatting" at the beginning
During Edit I see :
On the Forum it appears like this:
export function convertToMatrix(flatArray, uCount, vCount) { var result = zeroMatrix(uCount, vCount); for (var i = 0; i < uCount; i += 1) { for (var j = 0; j < vCount; j += 1) { result[i][j] = flatArray[i * vCount + j]; } } return result; }Let's see if this works.Simon Gatrall | Product Development, Engineering, Design, Onshape | Ex- IDEO, PCH, Unagi, Carbon | LinkedIn
Evan_Reese I test different way , and the html view toggle doesn't change anything.
For those who want to read the code it is not very pleasant without formatting.
What's weird is that it displays correctly while editing.
<div> skFitSpline(sketch1, "spline1", {</div><div> "points" : [</div><div> vector( 0 , 0) * centimeter,</div><div> vector( 100, 100) * centimeter</div><div> ],</div><div> "startDerivative" : vector(150 , 0) * centimeter,</div><div> "endDerivative" : vector(0 , 150) * centimeter,</div><div> });</div>Test of set to "code block" then paste:
<div> skFitSpline(sketch1, "spline1", {</div><div> "points" : [</div><div> vector( 0 , 0) * centimeter,</div><div> vector( 100, 100) * centimeter</div><div> ],</div><div> "startDerivative" : vector(150 , 0) * centimeter,</div><div> "endDerivative" : vector(0 , 150) * centimeter,</div><div> });</div>The Onsherpa | Reach peak Onshape productivity
When I write directly in the editor : it works normally
When I copy paste : it bugs
When I write a simple line of code , and I inspect it inside the code tag the text is:
After a copy paste the text is:
I seems that some <div> tag where added : I don't know if it is the editor who change the behaviour ?
you effectivly have to leave the HTML mode
