Improvements to Onshape - August 11th, 2023
cody_armstrong
Moderator, Onshape Employees, Developers, csevp Posts: 221
The non-stop cadence of improvements continues with another big update. It includes a long list of core improvements, so we hope you are as enthusiastic as we are. Let's dig in!
GENERAL IMPROVEMENTS
SET DEFAULT ROTATION BEHAVIOR
You can now set the default rotation to a constrained behavior. In the past, constrained rotation required holding down the Alt key.CURVE PATTERN IMPROVEMENTS
You can now define a Curve pattern by distance between instances.EXPLODE LINE IMPROVEMENTS
You can now hide (or show) all explode lines at once by right-clicking the Exploded view in the Exploded view panel.STANDARD CONTENT AUTHORING PERMISSIONS
Onshape Professional administrators will find a new authoring permission to control who in the company is allowed to edit Standard content.
RENAME DISPLAY STATES
You can now rename Display states.
STANDARD CONTENT PROPERTY IMPROVEMENTS
Individuals using the Onshape Free, Standard, or Education plans can now edit Standard content properties. In the past, this was limited to companies using Onshape Professional or Enterprise.DRAWING IMPROVEMENTS
CENTERMARK IMPROVEMENTS
You can now apply Centermarks to holes that are not normal to the view direction.
IMPROVEMENTS TO DRAWING VIEWS WITH FAULTY GEOMETRY
Faulty imported parts are now ignored by default when creating drawing views. You can also now choose to hide (or show) faulty imported geometry in assembly drawing views. Hiding faulty parts in drawing views can substantially improve performance.
RELEASE MANAGEMENT
SAVE RELEASE CANDIDATE DRAFTS
You can now save draft release candidates so that they can be completed later. This means big release candidates do not need to be created and submitted all at once.ENTERPRISE IMPROVEMENTS
UNPUBLISH CUSTOM WORKFLOWS
Onshape Enterprise Adminstrators now have an option to "Unpublish" workflows. This makes it easy for administrators to hide workflows that are no longer used. Unpublishing will not impact released or pending Release candidates using that workflow. This change only impacts new releases.
Remember: The updates listed here are now live for all users when creating new Documents. Over the next few days, these features will also be available in Documents created before this update.6
Love it! I've been wanting this for sometime but have always been distracted and never got an improvement request in. When working on a large release, the candidate is usually so laggy and sometimes, the browser view will suddenly require a refresh. Will be great to be able to save while editing it to avoid lost work.https://thesmoothcut.com/
Quality improvements. Thanks Team!
Woot, Rename Display States!
RENDERCAD
Note that you already had the option to "clone" a rejected release (to avoid re-creating everything from scratch):
- go to the version you wan to release
- right click (not left) on the rejected release in the version tree and then go to that release and pick "clone"
Do y'all have any updates on when Cloudmilling CAM will roll out? Or any more details about how it'll work?
and thanks for the excellent update (as usual)!
Twitter: @BryanLAGdesign
