Improvements to Onshape - August 11th, 2023
cody_armstrongcody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 221 image
edited September 2023 in New in Onshape
The non-stop cadence of improvements continues with another big update. It includes a long list of core improvements, so we hope you are as enthusiastic as we are. Let's dig in!
GENERAL IMPROVEMENTS
SET DEFAULT ROTATION BEHAVIOR
You can now set the default rotation to a constrained behavior. In the past, constrained rotation required holding down the Alt key.
https://onshape.wistia.com/medias/hsvkt0sldf
CURVE PATTERN IMPROVEMENTS
You can now define a Curve pattern by distance between instances.
https://onshape.wistia.com/medias/h19pqd88bs
EXPLODE LINE IMPROVEMENTS
You can now hide (or show) all explode lines at once by right-clicking the Exploded view in the Exploded view panel.
https://onshape.wistia.com/medias/v2n8n9rx37
STANDARD CONTENT AUTHORING PERMISSIONS
Onshape Professional administrators will find a new authoring permission to control who in the company is allowed to edit Standard content.
RENAME DISPLAY STATES
You can now rename Display states.
STANDARD CONTENT PROPERTY IMPROVEMENTS
Individuals using the Onshape Free, Standard, or Education plans can now edit Standard content properties. In the past, this was limited to companies using Onshape Professional or Enterprise.
DRAWING IMPROVEMENTS
CENTERMARK IMPROVEMENTS
You can now apply Centermarks to holes that are not normal to the view direction.
IMPROVEMENTS TO DRAWING VIEWS WITH FAULTY GEOMETRY
Faulty imported parts are now ignored by default when creating drawing views. You can also now choose to hide (or show) faulty imported geometry in assembly drawing views. Hiding faulty parts in drawing views can substantially improve performance.
RELEASE MANAGEMENT
SAVE RELEASE CANDIDATE DRAFTS
You can now save draft release candidates so that they can be completed later. This means big release candidates do not need to be created and submitted all at once.
https://onshape.wistia.com/medias/lt5c9tioao
ENTERPRISE IMPROVEMENTS
UNPUBLISH CUSTOM WORKFLOWS
Onshape Enterprise Adminstrators now have an option to "Unpublish" workflows. This makes it easy for administrators to hide workflows that are no longer used. Unpublishing will not impact released or pending Release candidates using that workflow. This change only impacts new releases.
  • MichaelPascoeMichaelPascoe Member Posts: 2,592 PRO
    edited August 2023
    Quality improvements. Thanks Team!
    Woot, Rename Display States!
    Great list of improvements!  Thankyou.  Save release will be handy
    edited August 2023
    I really like the little fastened to origin icon.  :):)
  • Lucas_KuhnsLucas_Kuhns Member, csevp Posts: 105 PRO
    Two very nice quality-of-life updates: release candidate drafts and renaming display states. Maybe now I'll actually use display states :)
  • james_mukisajames_mukisa Member Posts: 2
    WOW...
  • michael_zeaglermichael_zeagler Member Posts: 146 ✭✭✭
    Save release candidates is a huge one. If you get it kicked back, redoing everything is a huge pain. It could be such a minor fix and then you'd have to go through all that twice.
  • eric_pestyeric_pesty Member Posts: 2,391 PRO
    edited August 2023
    I Haven't tried the save option yet...
    Note that you already had the option to "clone" a rejected release (to avoid re-creating everything from scratch):
    - go to the version you wan to release
    - right click (not left) on the rejected release in the version tree and then go to that release and pick "clone"
    Oh that's new, I haven't used professional in at least a year. That's great.
  • david_riedelldavid_riedell Member Posts: 23 ✭✭
    These are some great changes!
    Do y'all have any updates on when Cloudmilling CAM will roll out? Or any more details about how it'll work?
  • jr_vrvrknjr_vrvrkn Member Posts: 125 PRO
    edited August 2023
    "You can now apply Centermarks to holes that are not normal to the view direction. " only works for actual hole features? not cilindrical faces?
    and thanks for the excellent update (as usual)!
  • Cache_River_MillCache_River_Mill Member Posts: 225 PRO
    Curve pattern. 👀
  • MatthewMatthew OS Professional, Developers, User Group Leader Posts: 27 PRO
    So now that we can save release candidates, can we keep working on the drawings until it's out of draft state and the changes be reflected in the RC?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,908 image
    Release drafts refer to the current workspace so you can make as many changes as you like before submitting the RC.
  • john_rousseaujohn_rousseau Member, Onshape Employees, Developers Posts: 415 image
    @david_riedell, as a rule we don't talk about release dates for upcoming functionality. We do realize how important CAM functionality is to our customers and we're just as excited as you are to get it released.
    En este enlace podéis ver las Novedades de Onshape en español:
    https://youtu.be/N5k2D4db9Rs
    Un saludo,
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 915 ✭✭✭✭✭
    Hoping that the next update we will see the new sheet metal loft functionality...... crossing fingers and toes!!!!!
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 458 PRO
    edited August 2023
    Sheet metal loft would be great! This is the only reason why I have to use traditional CAD Software  :#
  • PattabiPattabi Member Posts: 54 ✭✭
    Great improvements! Rename Display state and Center mark are the best...
    Still no dev diary  Page 7  Paradox Interactive Forums
