Right click menu not fully fitting on screen
Is anyone else having issues with the right click contextual menu often being too tall and not being able to use the top part without dragging the view so the part is lower on the screen? I would love it if there were some way for the menu to alter its position so its always visible on screen, no matter how close your active part is to the top. I dont have a huge monitor so its something Im getting really often.
I get the same problem with RMB on the features menu - for instance, in your screenshot, if I chose sketch 2 then the menu appears 'upwards' and I wouldn't be able to choose 'edit' from the list. The top of the list is covered by the bar with hamburger icon. I have to scroll up the features list, then choose from lower in the list to make the menu fit.
This isn't throw your toys out of the pram annoying, but it is pretty close. Basic comfortable UI stuff.
Here is my 13" screen from top to bottom:
I begin to test how chrome zooming affects on Onshape and I got to a situation where a simple RMB click would delete a feature. Menu flashed quickly and the pointer was on 'delete' as default and menu disappeared immediately and delete -command was performed (without LMB click).
In this case I was zooming heavily in and menu couldn't fit into screen anymore.
Thanks for sharing!
Im not complaining about it, I was just curious if its effecting anyone else or if there was some trick to avoid it. I can imagine the problem is not an easy one to solve when onshape is running in a browser but its good to know its being looked at.
It just happened to me again, on my Chromebook, but unlike your situation, it was not "heavily" zoomed - I was using (browser) zoom at 90%, on a 1366x768 screen
I would right-click on a sketch and the feature it was based on would instantly fail. (along with dependent down-stream features)
It's a bit like being at the bedside of a patient in an Intensive Care Unit, who goes into multiple system failure with no prior warning.
A user would have to be pretty alert to realise that the reason was that a single sketch had been deleted by that right-click, because on my system it happens almost before the RMB has time to display.
This is a serious misbehaviour, which I suspect is getting more prevalent as the RMB menu expands in length ... and I've submitted a sample model to Onshape Support under a Feedback ticket.
It is harder to stay on top of sneaky glitches in a package which is evolving continuously like Onshape, as opposed to the 'punctuated evolution' we are more used to.
This is very noticeable (and can be frustrating and demotivating) in Google Chrome OS, and Google Docs.
Of course there are massive countervailing advantages, but Onshape need to recognise that users, even power users, are never going to feel as familiar and as attuned to the finer points of behaviour as someone who has time to become intimately acquainted with every foible of an essentially steady-state interface (a year or longer, in the case of many of us who took "holidays" from maintenance on other packages, sometimes five years or more).
This also has the potential to make power users less likely to report bugs, because it's hard to pin down a useful and definitive description of what's going wrong when the context is not well understood. It's a bit like trying to say which tool is missing on someone else's workbench, rather than your own.
And I think that makes it all the more important to try to stamp out intermittent and fleeting glitches like this, at their earliest revelation.
@skippy I warmly recommend you second screen. I tried 2 screen setup ca. 7 years ago when I bought my first powerful laptop with 18" HD screen. I added another 20" monitor beside it and learn how to work bouncing stuff between screens - today I'm having difficulties to send email without 2. screen because it is SO nice to have all the necessary stuff on top.
The Material drop down is quite annoying see below.
Appears the the part I want to edit is always the last in the list.
It's NOT about being zoomed in too far: it happens to me regularly when zoomed out slightly, and only happens repeatably on my Chromebook
(90%, as mentioned above: if I revert to 100%, ie not zoomed in or out, the problem does not occur spontaneously)
and it happens ONLY when the list propagates upwards. (Which is a function of feature list length, and feature position on the list, and of RMB context menu length)
In my second screenshot, where the list propagates downwards (even for a sketch, which has a looong list of RMB options), the same behaviour does not happen spontaneously: in other words, I am not automatically presented with "Rename"
It's also not about an extra click: as you inferred above: a "Click-Drag-Release" option is being invoked by a single click, no matter how fast and crisply it is performed. It happens the same with a mouse as with a trackpad (which on the Chomebook requires a snakebite two-finger click).
However I cannot activate a "Click-Drag-Release" option using the Chrome Browser on my Windows laptop, and (presumably consequently) this bug hardly ever manifests itself on that combo, even when zoomed out to 90%
I had difficulties achieving the first screenshot without deleting Sketch 4, because the sketch was being deleted every single time I invoked the RMB menu.
I had to discover a workaround (which users who encounter this problem should note):
RMB on the feature, holding the button down, and drag away from the list into empty space, and release: this will leave the list open and selectable.
I haven't experimented to find out how to do this with a Chromebook trackpad: it won't be trivial!
(sorry the two screenshots are jammed together: I have not found a way to drag them apart
You may recognise the document, @3dcad !)
@lougallo tells me he's been able to reproduce this aberrant behaviour, and it does seem that it's the 90% zoom level which is the vital ingredient .... so now they should have enough info to work on a fix for this
(I'm guessing it's only on Chrome Browser, on Chromebooks)
This is great feature to make editing features and renaming parts faster (saves a click per instance). Sadly this doesn't work with w10 + chrome.
I got an email today stating that the problem was fixed in the 1.38.12894.8b5e19d92 version (which is what's current as of the time I'm writing this).
I'd like to report that the problem seems to be fixed (both my problem and the problem reported in this thread). The menu now appears over the status bar and/or upper bars, and it seems make the menu fit on the screen in a resasonable fashion. The only time I have a problem now is when the window is sized smaller than the height of the menu, which is typically not a problem (unless they add a bunch more features
