Is there a way to Lock the Z-axis of the part, when using the mouse to rotate the view of the part?
john_smith077john_smith077 Member Posts: 175 ✭✭✭
Hello
When using your mouse to rotate the part, is there any way to "genuinely" lock the part so that the view can ONLY rotate around the Z-axis of the part itself?
Holding down Alt + RMB is doing something different... (It does keep Z-direction lines vertical, however also allows you to "pull the Z-axis of the part towards you" as is were...)
J
