Is it possible to extrude/loft-cut using a solid shape as a tool?
I'm trying to create a mockup of a thermo-molded tray that will cradle a complex 3D shape. I was hoping I could position the part in its final place, then extrude the tray from the mold direction using the solid part as a tool. I think extrude are only for sketches/faces, and boolean isn't sufficient since the complex shape would result in several undercuts.
Thanks!
Christian Petty - Mechanical Design Engineer, Radian R&D
Longer answer, you'll probably want to use the isocline tool to split the surfaces of the part using whatever draft angle is recommended for your thermoforming, and then use ruled surfaces at that same draft angle from those splits to create the surfaces which avoid the undercuts. There will be some surfacing work to either make an enclosed solid "tool" or a surface tool to split your tray base part. Boolean has a nice option to offset the tool body which can be helpful for tolerance reasons with something like a thermoformed tray.
Seems like you should be able to succed by extruding a projected contour and splitting the resulting solid with the (extendend) part surface contacting the mold.
That's exactly how I'd approach it too.
A quick Boolean subtract seams to give a cradle shape.
https://cad.onshape.com/documents/ae39d9785e9d8914ab10960a/w/459cc02062d9e0ceed4ed0be/e/3446e2e18785c2780f69ac71
I believe the goal is to find a way to press the object into a tray at any orientation without creating undercuts, like this example. I think a manual workflow like this is could be the way to go for a general case, but if you can get away with modeling some of it separately (or splitting and recombining it) you could project each body and extrude up to it to get a start, like this example.
was out a few days.
@christian_petty Is this solved then?
@Evan_Reese s solution to me is quite elegant and closely resembles what I would propose.
So essentially a tool path like I used in SW would be one answer.
I get it now, there used to be a similar command in creo as well, if I remember correctly.
you could "sweep" or "extrude" a solid body (or essentially its contour relative to the sweeping curve/ axis respectively)
would be nice indeed.
