constraints will not finalize
I'm doing the Multi-part studios exercise. I went all the way through the clamp build and everything worked fine right up until I tried to change the dimensions then the part constraints on the 50mm pivot circle wouldn't change with the dimension changes. I went back and started the sketch drawing over several more times, but now I can't get the master sketch to finalize. I'm lost to what is going on.
Any help.
