Sweep/Loft General Question
yuggniiks
Member Posts: 25 EDU
Hello,
I'm attempting to create a small air manifold, and create 6 holes that merge into one.
I'll continue to search and experiment but would love to see the different ways to achieve this.
https://cad.onshape.com/documents/b2005ccd767fd0c378b1d1e0/w/dae4f99b5d22442a933f3ac0/e/8aa63d8bb4a3af79bdbe4d99?renderMode=0&uiState=64f8de2d5476b8172ae22176
Thanks for your time and knowledge sharing!
-Alan
-Alan
Matthew_Curran
Member, csevp Posts: 24 PRO
Not the most elegant solution, but by projecting the intersection of each hole onto a sketch I was able to create a chamber using loft.
https://cad.onshape.com/documents/d65436f7e6177c05ebb9d44c/w/a7afdb0e82baff883003861c/e/e6ef2284e06bf4f86e7d5226
1
https://cad.onshape.com/documents/723ddc33f331946c7e024449/w/d211a03ab9cb1b7b4ab3acff/e/2d67b10adf29a18a4e6b8536
https://cad.onshape.com/documents/723ddc33f331946c7e024449/w/d211a03ab9cb1b7b4ab3acff/e/311d6800fc36a7e9f8d3b2f5
You might get "cleaner" results if the bottom corners were concentric with the corner holes like this:
eric_pesty thanks for an additional solution. I haven't thought fully about what is req'd or would work for my application. The manifold is bringing in (6) 1/4" diameter air lines supplying ecig vapor. They funnel down to one, and ultimately for use in MRI for human participants. This is going to be iterative and maybe I can save material and use your second solution.
Appreciate the knowledge! Thanks!!
