Extruding from edge of a part
rodrigo_martinelli
Member Posts: 7 ✭
Hi, i'm trying to extrude a surface using the edges of a part, is that possible?
I hope the images are good enough, what i need to do is, extrude that edge 2mm normal to the face on the whole perimeter, then "inset it" and later, translate it since it's at an angle..
Link to the document:
https://cad.onshape.com/documents/6ac1588d8f0df3e496efbbcd/w/412be63a927c4176b17a92be/e/850adb4ac7b275935be0ed53
MichaelPascoe
Member Posts: 2,818 PRO
RENDERCAD
________________________________________________________________________0
Hi @rodrigo_martinelli, this is possible with Ruled surface.
RENDERCAD
