how can i mirror a part in assemblies?
andrew_gorman
Member Posts: 1 ✭✭
I'm working on a simple knife project and want to mirror the handle scales in the assembly...can't see how to do this right now? Any advise?
I need mirror assemblies often, What I did was similar to Bruce's suggestion.
But I added a mate connector on the origin, then mate all the parts in the assembly with that mate.
Although when i do this, my intent is to have it mirrored around the origin, you should consider all methods and choose one that fits your project best.
Owen's is good for a sales drawing, but like they said, each instance will be a new part, so not very viable if you want a parametric BOM.
Bruce's is good as it creates a part in a logical place that you can choose while inserting, you will just need to rebuild/replace your parts manually in the assembly as needed.
The mate connector can be tied to a configuration which allows you to use the "replace parts" in the assembly and get your mates for free.
Here is a video showing the workflow, It can be very tedious if you need to do an entire assembly, but for a few parts in a larger assembly, this would be fine.
As you see in the second half of the video, full assemblies are faster to just re-insert and mate the normal way.
Each part that I do a "replace part" and choose the CCW configuration, is a mirrored part in the part studio, with the mate connector being re-defined in the configuration.
Even though all the mates will be attached, you may need to edit and rotate them here or there, as you can see, I only had to do it to the bottom shingle 180°
Hope this helps
Thank you,
Janik
This is what it looks like when you mirror it in the context assembly.
The tool is the part studio icon with the plus.
I hope this is what you are looking for.
Axel Kollmenter
How is this still a thing? I just duplicated the part studio and mirrored the parts that needed it, then placed it in assembly again. Quite a pain as it required organising, repositioning and adding mates again. Please add this feature already.
Couldn't put it any better:
it's by far the most voted improvement request.
so much more important for the users than the stuff that are being presented in the latest updates.
I have a more detailed question about it, I'll post it in the improvement request thread.
Neither of which onshape can produce...
One more thing to note @Gerard_Boterman
If you reference the origin in an assembly. Be sure to mate that reference to your fixed part is some way also.
Otherwise, the patterned part will float around in a higher-level assembly. Sometimes this is what you want, but I assume by default this will cause confusion coming from other CAD systems. Where Assemblies are always static.
Typically, I try to avoid referencing the origin unless I'm mating the "Main Body" to it, rather than using "Fix".
Even in SolidWorks the better way of mirroring is at the part level not in the assembly because if something happens to the assembly still the mirroring is correct if you do it at part level. (For example later you want to do Pack&Go and use only the parts in somewhere then it helps). If you can derive the part into a new part studio there you can simply create the mirrored version and import into an assembly later.
