Extruding from edge of a part
Hi, i'm trying to extrude a surface using the edges of a part, is that possible?
I hope the images are good enough, what i need to do is, extrude that edge 2mm normal to the face on the whole perimeter, then "inset it" and later, translate it since it's at an angle..
Link to the document:
https://cad.onshape.com/documents/6ac1588d8f0df3e496efbbcd/w/412be63a927c4176b17a92be/e/850adb4ac7b275935be0ed53
MichaelPascoe Member Posts: 2,390 PRO
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴0
Hi @rodrigo_martinelli, this is possible with Ruled surface.
