Is it possible to flip or mirror an imported image?
prem_hall603prem_hall603 Member Posts: 2
Hi, So I'm working on an RC touring car, Specifically the BMW E30 model. I want to model the shell on the car and tried to flip an image of multiple perspectives of the model. I want to know if it'd be possible to change the view of the car?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,844
    No, you’ll have to edit it in an image editing program first.
  • thor_zweegersthor_zweegers Member Posts: 2
    Is this still a thing? I can't figure it out and can't imagine this hasn't been fixed in an update in the last 4 years
  • EvanReeseEvanReese Member, Mentor Posts: 2,329 ✭✭✭✭✭
    I don't think it's been changed, but works well enough for me as-is. Are you familiar with sketching on implicit mate connectors? You can flip those, which will flip your image.
    Independent Onshape Consultant | Industrial Designer
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 945 PRO
    Why wouldn't you simply do it in any photo editing app? I don't see that as a CAD core competency function. A picture is generally used as a visual reference to make lines/curves in cad, then never used again.
  • eric_pestyeric_pesty Member Posts: 2,126 PRO
    edited September 2023
    @thor_zweegers,
    The image tool is fairly basic so better to "prep" your picture in an external tool as you probably need to crop it as well before importing...
    The "Image" Featurescript is an alternative that provides other functionality as well to help with sizing (and you can flip the MC easily):
    https://cad.onshape.com/documents/f7a45d78c374497d37c1d2cb/v/a9e78475a009e142f2ebb3d1/e/557019cd8b843cc475681faf
