chadstoltzfus@premiercb.com
Looks like using expressions can be extremely efficient, but not very intuitive to implement or edit.
One one hand I am tempted to use the expressions but on the other hand I fear that my coworkers will not be able to work with parts that contain these complex features.
Wow. Fantastic update!! Ty Onshape team!
Really excited about the "Convert to expression" and the "Where used" for custom features.
When trying it out, it appears that "Convert to expression" is not available for configuration booleans yet. =(
No doubt it's planned for future awesome updates!
@_anton Legit!
This resolved an earlier issue I had. (moving faces in imported part in one or the other way based on a positive or negative value in an expression)
Would be very handy to reference the initial input parameters on the final drawing as a confirmation to the customer;
Question on the list view, the video talks about "not having to remember folder structure" but it doesn't seem to bring up stuff from subfolders "recursively"... Am I missing something here?
Also anyone else wished it would keep the filters as you switch folder?
I could see other litmus tests for displaying info in the list.
- Has a version been created?
- Does the part/assembly/drawing have a part number assigned?
- Is the part or subassembly used in an assembly?
- Has a drawing been created for it?
These are all steps toward something becoming a real thing that is being tracked.Simon Gatrall | Staff Mechanical Engineer | Carbon, Inc.
Regarding the filter state being dropped on navigation, this is a bug that needs a fix, but might be related to some other contingencies in progress. I've created a support ticket for you.
In regards to being able restrict certain types of views of your data, yes we hear this and know it's important. The very clear case is perhaps letting some role or group of users such as the "Shop floor" only see the latest released data, but not be able to easily see documents or other data in other non released states.
Since we don't use that crap, this filter is just blank.
naw,
We have a single document that is shared with the everyone on our Team called "Active Jobs"
They are the exported PDFs which by our company standards must be Quantity checked and initialed by hand on the official drawing.
any drawing that has that area blank is not allowed to be manufactured.
The reason for this is we use that as a double check to make sure we didn't have a typo on the QTY stamp, or sometimes we may want a couple extra for this batch for spare parts.
As parts get manufactured there may be errors or improvements, they red line the drawing and we drop what we are doing and make the change and re-release the drawing if necessary. The PDFs on Onshape are constantly being updated. So everyone in the shop only is exposed to the official stuff.
Being in Onshape means we don't have to run around to 20 different computers and close the open files every time there is a change, and we can also see who is currently viewing the PDF so we know if anyone needs to be informed.
When the job is done, we ship and pull the final PDF OFF of Onshape and save it on our server for History. Then as changes come in after final install/run-off they get updated and saved on our server as AS-BUILT
So, the only files the shop can see are drawings that are Released/Validated/Active that way the actual "Paper" with the hand written notes is what you see even if you are out of town viewing online.
Since the model is in a state of constant change, and most of our staff are not very computer savvy.
We have decreed nobody except the Designer is able to spoon feed the correct Drawing or Step File.
They can view and rotate the Assembly directly, but we throw an internet link in our job folder on the server so they are viewing the correct branch or whatever.
It's basically a manual release management. That works with both SolidWorks and Onshape, since we are still 50/50 on our releases right now.
If only we could put an eDrawing as an Onshape tab... I still have to go down and look at every damn computer until I find the one person who had the model read-only...
I attempted Onshape's release management once before, but it just felt like even more work for something nobody in the shop is allowed access to anyway.
Maybe it's updated since then and I should re-investigate it. But from what I've seen it was just another headache on top of what I already have to do anyway.
As for my comment above about wanting to be able to filter without using release management is, I want to use that feature as design tool as I'm designing.
for example a support ticket I have out I had to explain the document structure because there was odd behavior on the BOMs at the top level.
So I sent this image.
It would have been nice to just turn on your built in filter
Twitter: @BryanLAGdesign
We should make some "Onshape Update - Bingo Cards"
On my card are the following features:
That would be awesome
Onshape Bingo | Assembly 1
Is this a wish list or are we betting on what will be implemented? Here are some of my top wishes:
Then copy that assembly for each score card, then scramble thier positions and change them up
Once a ir is made, change the color and name in the partstudio config and all the score cards will update
After a few months someone aught to win
Awesome idea! We should try to imprint the text of each IR on a box.
Is there a way to randomize the position with a seed value? Since true tandomie is not possible in FeatureScript.
Maybe we can use the forum user name as seed, so everyone gets his unique bingo card.
@S1mon We can use a mix of our personal favorites and maybe the top voted IRs. We need 25 in total.
I would add a link to each IR in the description where "yada yada" is.
Then there would be a big assembly that shows all the active players on a big table.
