Spindle Shoulders
fred_wildfred_wild Member Posts: 29
A common lathe operation takes the stock from a square cross-section to a round cross-section.  The transition over a short distance leaves an arc on the flat face as the cut slopes into the stock.  My efforts to model the effect in Onshape using Revolve and Loft did not succeed.  Is there a method or Onshape tool useful in the purpose?  Thank you.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    No loft required. Model it as you would machine it. Start with square stock then sketch the entire shape for the revolve (including the runout).
  • fred_wildfred_wild Member Posts: 29
    Thank you for your response, but I don't understand.  If I extrude from the sketch to the square stock and revolve the adjacent transition, Onshape circumscribes it as a bead within the square butt. (See attached).  What am I doing wrong?  Thank you.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,478 PRO
    Make the square part the whole length and use a revolve with "remove"
