Trackpad
Is it possible to design with just the trackpad or will I need a mouse?
  • S1monS1mon Member Posts: 3,773 PRO
    It's very possible, but a mouse is much easier in my opinion. You'll want to use the Onshape defaults for the controls in order for the trackpad to work.
    https://forum.onshape.com/discussion/14648/handling-without-a-mouse
  • EvanReeseEvanReese Member, Mentor Posts: 2,693 PRO
    I still prefer to use a mouse and 3DConnexion Spacemouse for serious sessions, but I use just a trackpad very often and it's totally doable. I'm on a macbook pro and the trackpad is pretty big which helps.
  • grochinogrochino Moderator, Onshape Employees, User Group Leader Posts: 44 image
    It's definitely possible to use only a trackpad. I've exclusively been using a trackpad on my MacBook Pro for Onshape for the past few years.
