How to change Onshape Region
don_bdon_b Member Posts: 152 ✭✭
edited September 2023 in Community Support
I have long latency and from the east coast am on us-west-2 with better latency in ca-central-1 (Central) or us-east-1 (Virginia) or us-east-2 (Ohio)
How do I change to a different location
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,930 image
    us-west-2 is your closest region. What latency values is Onshape reporting and what are you experiencing that makes you think latency is the problem?
  • don_bdon_b Member Posts: 152 ✭✭
    used the tool 78 vs 19 Virginia or Ohio much closer
    l have slowed regens
    Onshape's performance tool? 78ms is fine and has no effect on regen time. Take a look at the regen times button in the top right corner of the feature list to see where the bottleneck is. Also, how many features in your feature list?
    doing everything I can to speed it up..... I have obviously too many derived but geometry requires it
    simple question... how do I change regions
    I refer to my previous answers - "us-west-2 is your closest region" - "has no effect on regen time" - chaining workspace derived features is a sure way to bog things down - swap to versions instead or use in-context.
