Enveloping components
Is there a way to envelope components similarly to Solidworks Envelope functionality?
3
CAD Engineering Manager
I will explain a bit more, what I would like to see in Onshape.
Enveloping a part/assembly would mean that it is principally excluded from BOM and it would be visible in models with a different appearance (in Solidworks it is something like 75% transparency and green). In onshape company settings that is good to be configured - as some may want to have some different color.
The principal idea behind that is to fill in the design with a "ghost" model of a component, that can also be used to reference features within the design.
In drawings, by default, these enveloped components are hidden, unless you specify otherwise in view properties to have them visible.
There are some use cases, let's say "current" document/assembly, in which some part of the design (a subassembly) has to be defined and released in some other document/assembly BOM, but one still needs to visualize the presence of this subassembly, in "current" document/assembly.
Or, for instance, the presence of a manufactured/manipulated object in a production line. The product has a presence as an enveloped component within a machine and it will not be visible in BOM and drawings (unless view configured otherwise)...
https://forum.onshape.com/discussion/22031/enveloping-components#latest
Please vote if you also see it as a necessary feature.
I was wondering what was meant by enveloping. Haven't worked in SW much for some time now.
https://cad.onshape.com/documents/6164a183c20441bb781f7cd0/w/ccde88345499b28baa265f85/e/51e8970e41bd2b66ee9d1620
Yes, there is indeed such functionality to exclude from BOM, but in some instances, I'd like to emphasize these parts/assemblies are excluded from BOM by having correct visual feedback.
There is no way of knowing which parts are actually excluded from BOM, by just looking at the 3D model.
Envelope in its essence allows to differentiate excluded parts visually in 3D and allows to control visibility in drawings.
It's actually a really powerful tool once you know how to take advantage on it.
I'd like to see this simplified since it would be quite useful.
https://cad.onshape.com/documents/6164a183c20441bb781f7cd0/w/ccde88345499b28baa265f85/e/251df18e1ecaddb0e6bb5224
You can definitely do it with an assembly configuration by creatin an in-context "block" in your sub-assembly and have a configuration of the sub-assembly where only this "block" is un-suppressed, you can also configure the BOM behavior so nothing show up when in that configuration.
If you used a Featurescript for it you could make it so the transparency/color was always the same to remove some of the manual steps (starting with the "calculate bounds" and adding setting the appearance).
However that wouldn't help in the drawings though as there is no way to "mix" appearances so it would be a "solid" box (unless you used a shaded view).
@Andres_Oss
I just finished some updates for the post above to complete intended BOM behavior's.
I'll have a look back through top down design for Volume Allocation.
