Move sketch to the origin
andrea_boschettiandrea_boschetti Member Posts: 7
When I import a sketch sometimes it is imported very far to the origin so is difficult to find it. is it possible to move the sketch to the origin?
thank you in advance
  • sharjeel_faizsharjeel_faiz Member Posts: 6
    This was an excellent video. Thanks
  • tyler_durden157tyler_durden157 Member Posts: 4
    would be good if there was a button "Center and Arrange" that would do this automatically instead of the current solution
  • rraffaell73rraffaell73 Member Posts: 8
    When the imported file is in STL format, for example, there is no option to use the Transform command in the tools... How do I move this imported file to the origin?
  • glen_dewsburyglen_dewsbury Member Posts: 1,124 PRO
    edited December 2023
    The transform tool works fine.
    https://cad.onshape.com/documents/b90a63cec600990649097202/w/e4d74e1141bd02032f427eb7/e/2fa4774abb25fa0b115ca56d
    Main, transformed by x.y.z o a given distance.
    If you don't know the distance or can't measure the distance directly then look at suppressed items to make a sketch that can give measurements.
    version 2, transformed by points
    I did sketch a new point where I wanted to transform the stl from.
    version 1, original location
  • robert_scott_jr_robert_scott_jr_ Member Posts: 623 ✭✭✭
    To avoid confusion: There are two Transform tools. One is used inside a sketch to deal with sketch entities. The other is outside of a sketch for parts and surfaces. - Scotty
  • kari_harju393kari_harju393 Member Posts: 2
    @robert_scott_jr_ cannot thank you enough for this comment.. I was about to just switch to another tool. 😅
    SW developer myself, "naming is hard" is my most used phrase, but the video in this case already uses the terminology that I think the software itself should definitely also use and show.
    Having the tool names be "Transform Sketch" and "Transform Parts" instead of "Transform" visible in the command-palette and hover items would make this visible in every tutorial and guide.
    From a "freshman" OnShape user coming from other tools, a good portion of the guides, documentation and tutorial seems to miss the: "You are in this mode now, so the same tool name is a totally different tool".
    This gets REALLY frustrating, as this is an online tool the first question is always:
    "Is the guide obsolete on an older version..? ..or why am I not seeing the tools talked about?"
    …which is a super frustrating place to be.
  • S1monS1mon Member Posts: 3,460 PRO
    In a way there are 3 transform tools. One in sketcher (non-parametric) which operates on sketch entities, one is a feature in a part studio (parametric) which works on curves, surfaces and parts, and the other is a tool in assembly tabs whenever you select a part or sub-assembly (also non-parametric).
