Gear Mate changing start angle for crankshaft and camshaft relation.
ernie_soehl
Member Posts: 4 EDU
I am trying to animate my engine and link the crankshaft to the cam shaft using the gear selection which I did fine and it works, but now I am trying to get it timed to see the tolerances. When I try to advance the cam shaft fowards 90 degrees to see where it is it moves the cam and the crankshaft. I have tried may different ways and read other forums for help but cant seem to get it to work. Ive tried opening the revolute mates and change the angle in there, and I've tried deleting the gear relation and doing it before hand, but nothing is working. I have only been doing cad for 2 weeks now so I am still new so any help will be much appreciated.
https://cad.onshape.com/documents/99366efbf7f4a5c565b6e546/w/f93097c1041154390f7a8354/e/58190533cb94b1d8336f905a?renderMode=0&uiState=6524a37ca4acad544d96eaeb
